smart-sensor
        Displays smart-sensor
            trigger and scan status. The Smart-sensor feature auto-provisions tri-radio APs as
            sensors. Smart-sensor uses an algorithmic function to identify tri-radio APs best suited
            to be provisioned as sensors. Use this command to view the calibration and scan status.
        Supported in the following
                platforms:
                - Access Points — AP4XX, AP8533
                - Service Platforms — NX5500,
                    NX7500, NX9500, NX9600, VX9000
        Syntax
            show smart-sensor [scan-status|automatic-trigger-status]
        Parameters
                            | smart-sensor |
                            Displays Smart-sensor related statistics, such as auto-trigger
                                status |
                            | scan-status |
                            Displays Smart-sensor scan status |
                            | automatic-trigger-status |
                            Displays automatic-trigger status. After the Smart-sensor
                                calibration is triggered, use this option to view if the calibration
                                is in progress or has completed. |
            ap8533-06F89E#show smart-sensor automatic-trigger-status
RF-DOMAIN           STATE
smart         calibration-completed
ap8533-06F89E#
            ap8533-06F89E#show smart-sensor scan-status
RADIO-MAC              SCAN-STATE
74-67-F7-08-D7-A0        DONE
74-67-F7-6D-43-90        DONE
Total number of radios displayed: 2
ap8533-06F89E#
